It is a magnet that floats (onnects like a reed switch inside the machine)
if it doesn't float there is the problem read switch does not pick up telling the machine ther is no water in the container
it can stick to the container and doesn't float
bad design
try hot water and wash away the film that could be holding it down
might work for you
Micky
Lucky for you the problem probably doesn't lie with the machine but the water tank. Inside the tank there is a flow meter (that little black box). That black box contains a pc board that connects to the machine to tell it how much water is currently available. If that piece does not work properly and the flow meter does not rise (inside, you can't really see it) when water is put into the tank, your machine will think there is not water available to make espresso. Try replacing the tank first then go from there.
