Posted on Sep 20, 2010
My machine Xerox Work Centre Pro 420 shows U4 in the display
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
408
Points
My machine xerox 420 problam is U4
plz tell me the how to reslove this problam
v sudarshan.rao
Level 1:
New Friend:
  • Posted on Dec 02, 2014
v sudarshan.rao
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
408
Points
Swith off machine hold zero and on machine than press 10 and than1 change the value 0 to 1 than off anf on machine
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
How do I reset error code u4 using the control panel?
Switch off the M/C then press & hold zero button & on still when screen will display (---) then press '10' start button '1' start button. now your M/C showing 3 so you change it press '0' button then switch off &on
2helpful
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
3helpful
2answers
1helpful
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
6helpful
2answers
Problems with my MODI XEROX 5216
It can not copy. When I power on after 30 seconds the copier show U4 in the screen and do not work.
Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
3helpful
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
