Tip & How-To about 2007 BMW 760Li Sedan
ATE currently produces and markets two DOT4 brake fluids with the identical specifications: * Dry boiling point of 536 degrees Farenheit which is 122 degrees Farenheit above DOT4 Specifications, which is Super Racing Blue * Wet boiling point of 392 degrees Farenheit which is 113 degrees Farenheit above DOT4 Specifications, which is Original Brake Fluid TVP 200. Other than packaging, the primary difference between the two is color. The Blue is blue in color and the 200 is clear or light amber in color. This facilitates flushing and changing fluid such that if used alternately, the flusher will know that the job is done correctly when the color change is complete.
