SOURCE: GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
SOURCE: dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
SOURCE: microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in
materials or workmanship. During this nine-year limited warranty, you
will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will
send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to
microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is
it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find
helpful exploded view diagrams and order parts if needed by entering your full
model number from the tag on the oven here.
Let us know what you find out or decide.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: I have a ge profile microwave,convection oven,
F3 on a GE / Hotpoint
microwave means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10977 and you can get it here for $56.18 (compared to $93.00 from GE!).
You can find
links to helpful exploded view diagrams and part ordering help
here.
I'd recommend that your bookmark this link to your favorites.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock as shown below:
We're
