,. What is dynamic IP address,? what is the difference between normal IP address and Dynamic IP address
Hai there are two types of ip address provided by your internet service provider.
1) Static ip
2)Dynamic ip
Dynamic ip means changeable ip address when ever you log on to the internet.
Static ip address doesn't change , A specific ip address assign for you by your ISP..
You can check your ip address whether it is static or dynamic at Ip-Details.com
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
There are two kinds of IP addresses: Dynamic and Static. A dynamic IP address changes (refreshes)from time to time while a static IP address remains constant. Dynamic IP is in most cases considerably cheaper than a static IP which for single users probably isn't worth the extra expense.
An IP
address conflict occurs
when two computers on a LAN or the Internet have been assigned the same IP. IP
conflicts between two computers normally render either one or both of them
unusable for network operations.
How IP
Address Conflicts Happen
Two
computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two
computers on the LAN the same Static IP Address.
· A system administrator assigns a
computer a static IP address within the local network's DHCP range (dynamic IP
range), and the same address is automatically assigned by the LAN DHCP
server.
· A malfunction in the network's DHCP
server allows the same dynamic address to automatically be assigned to multiple
computers.
· An ISP accidentally assigns two
customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby
/ hibernate mode and then awakened later.
Note that
other forms of IP conflicts can also occur on a network. For example, one computer
may experience an IP address conflict with itself if that computer is
configured with multiple Network Adapters. System administrators may also
create IP conflicts by accidentally connecting two ports of a network switch or
router to each other.
Recognizing
IP Address Conflicts
On most
Microsoft Windows computers, if you attempt to set a fixed (static) IP address
that is already active on the local network, you will receive the following
pop-up error message:
The static IP address that was just configured is already in use on the
network. Please reconfigure a different IP address.
On newer
Microsoft Windows computers having dynamic IP conflicts, you should receive a
balloon error message in the Taskbar as soon as the operating system detects
the issue:
There is an IP address conflict with another system on the network.
Sometimes,
especially on older Windows computers, a message similar to the following may
instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or
Linux computers, a similar message will normally appear on screen.
Resolving IP
Address Conflicts
Try the
following remedies for IP conflicts:
1. For
networks where IP addresses are fixed (statically assigned), ensure each local
host is configured with a
unique IP address.
2. If your
computer has a dynamically assigned address, releasing
and renewing its IP address can
workaround IP address conflicts.
3. If your home router is believed to have a
faulty DHCP server causing IP conflicts on the home network, upgrading the
router firmware may resolve this problem.
"Static IP addressing is for one customer on one IP address and
Dynamic IP addressing assigns a different IP address each time the ISP
customer logs on to their computer, but this is dependent upon the
Internet Service Provider (ISP) because some ISP's only change the IP
address as they deem it necessary.
If you have Dynamic IP Addressing through your Website Host it means
that you are sharing an IP Address with several other customers.
If you are a beginner on the internet, an avid internet user, are
entertaining the thought of starting your own website business, are a
gamer, use VOIP or VPN there are several things you should know about IP
Addressing."
how can I know my trend net Ip?
