NEC VT695 LCD Projector Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there anyway that i can connect a nec vt695 to my tv
Ekse
Level 3:
  • NEC Master 13,435 Answers
  • Posted on Sep 20, 2010
Ekse
NEC Master
Level 3:
Answers
13435
Questions
82
Helped
3983126
Points
38023
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Why does status light flash red on VT695 proxima?
Usually it's a warning that the lamp is either close to it's end of life or it has expired.
1helpful
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
Nec vt 695 status light blinking four times after replacing new bulb
one of the fans in the projector is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Having a problem getting past the red blinking status and orange blinking when trying to start up a NEC VT595 projector. This is after installing a new bulb.
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
I want to connect my iPad 2 to the NEC video projector VT695. do I need a VGA or an AV adaptor?
you need this ----------- Apple MC552ZM/A Video Cable Adapter HD-15 Video - Male Proprietary
2helpful
I have yellow spot on my projector
Blue LCD panel requires replacement.
How do i unlock my nec vt660 projector?
cabinet lock need remote control to unlock
NEC VT695 (not a vt570) bad lamp blowing ballast board?
We have the same model here at our school too. I know of two that have done exactly what you said. I am trying to figure out if this is NEC fault. Bulbs are expensive and if the projector and NEC is a fault; we will definitely be moving on to a different brand.
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
