We tried all suggested ideas. recharged, discharged, cleaned all ports ect. still not working.
ready for the next step.We tried all suggested ideas. recharged, discharged, cleaned all ports ect. still not working.
AnonymousJul 20, 2008
Screen is blank when I turn on the camera. Full recharged the battery and still nothing. The lens will not even open up.Screen is blank when I turn on the camera. Full recharged the battery and still nothing. The lens will not even open up.
You can't post conmments that contain an email address.
Possible causes and how to handle them 1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty. Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
You don't. The Z730 works with MMC and SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use cards 2GB and smaller.
The problem that you describe indicates that your Kodak EasyShare software has somehow become corrupted. Uninstall the software (use the uninstall feature, not just delete) then download and install the current software from the kodak.com web site (this is a no-cost download). That should cure the problem, but if it doesn't I suggest that you contact Kodak customer service via their web site.
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable 1 Turn off the camera. 2 Plug the labeled end of the USB cable into the USB port on your computer. 3 Plug the other end of the USB cable into the USB port on the camera. 4 Turn on the camera. Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
Does the "unlock" button depress? When my dial seemed to freeze, or turn very hard, I lightly coated a small piece of newspaper with petroleum jelly (both sides) and slid it all around under the dial. This lubricated the plastic and made it turn freely. Good luck!
