If the refrigerated water light on your Haier HRF6631SB2/U fridge freezer is showing red, it could indicate a problem with the water dispenser. Here are a few things you can try to fix the issue:
- Check the water supply: Make sure the water supply to the fridge is turned on and that the water supply valve is not closed or clogged.
- Check the water filter: Make sure the water filter is not clogged. If the filter is dirty, replace it with a new one.
- Check the water inlet valve: Make sure the water inlet valve is not clogged or damaged. The valve may need to be cleaned or replaced.
- Check the water dispenser line: Make sure the water dispenser line is not clogged or frozen. If the line is frozen, defrost it.
- Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
