SOURCE: old dishwasher doesn't drain
Disconnect the drain line from the sink and put it in a pail.
Turn the timer to a pump out cycle and see what comes out of the drain.
If it still drains poorly, replace the pump impeller.
SOURCE: i have a kitchenaid superba dishwasher wont drain
does it make a buzzing sound when on pump? if so then the pump is trying but is either jammed or there is a blockage in the waste hose/outlet u bend. try seeing if there is a blockage in the waste hose first.
SOURCE: KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
the problem is hard water in your area. www.dishwasherfilter.com has a new product out that will solve this problem. it filters the water before it goes into your dishwasher. very affordable and works amazing. get it at www.dishwasherfilter.com.
SOURCE: I have a kitchenaide Superba
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
