Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Testimonial: "Thanks caroldon, but it sounds complicated. How do I check the transformer?"
Thanks Caroldon, but it sounds slightly complicated. How do I check the transformer? Is it just 4 screws and the oven falls forward?
Check the power cord , trace it all the way in to the clock board , the transformer must be inthe front end., a multiimeter check will prove it working, an open connection means faulty.Take a try.
