I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
This does not sound like a power board problem at all. This is either a defect in your LCD panel or in the main video board.
Honestly though, by your description it sounds like there's a small crack in your screen. Maybe I'm just not understanding your description, but small black lines and a change in brightness on one side of the screen usually indicates some sort of damage to the panel. It most likely will be better to live with this problem.
Alternatively, your panel may have shifted inside the casing, but I can't imagine that happening by itself, with the casing sustaining some damage.
Either way, if you open it up and find bad caps on the power board (you might find some even though that's not causing your problem) you should replace them as a preventative measure, but you should also look at the panel itself and make sure it hasn't been damaged in some way.
Anyways, good luck, and all the best.
Your problem is in the signal board. There are some capacitors in the signal board that are bad. You describe exactly what bad capacitors can do to a flat panel LCD TV. Once, again you will need a capacitor checker to find these. A weak or bad cap will leave lighter shades as well as black bars on the screen. Please be careful as not to tear the traces on the PCB when removing a cap. Be careful and have lots of patience!
Its a defect in the right side lcd pattern bord an typicaly its the 1st ribon cable on the right half going from the center to the right there is a micro buffer in the ribon cable an the connections to it in the cable go bad only way to fix it is to replace the entier lcd screen with both left and right pattern bords atached to the ribons
its not capacitors or signal bords it is the lcd screen its self
hope this helps others with this problem
