I have re-installed my original software 3 times on for my C3180. I am able to print but not scan or anything else. I get a "HPIO Trap Monitor Not Launched" message. When I try to use the Assist me Set-up, no printers appear in the list. I am using a MacBook Pro. My scanner. Now it doesn't. Please help.
See if this link helps you out you might find your manual on this page.
HP Photosmart C3180 All In One InkJet Printer manual Google Search
SOURCE: can't scan PLEASE HELP!
SOLUTION:
Download
the latest version (v 7.7.2) of the HP software from the HP website at
www.hp.com. Uninstall the previous software and then reinstall the
downloaded software.
WORKAROUND:
Follow the steps below:
SOURCE: When installing the 6310 all
There are two ways for install the Scanner
using only "the driver" and using "HP Photosmart Studio Includes
Support for Mac OS X v10.3, v10.4 and v10.5 (Leopard)" using the driver
not include IRIS OCR software only the driver to scan and thats why say
"An OCR error ocurred, couldn't create file". Installing the HP
Photosmart Studio fix the problem.
If fixed the problem visit my page www.richardsite.com.mx
SOURCE: HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
SOURCE: Have USB connected MacBook Pro
According
to your problem first reinstall the Mac version of the scanner driver. If you
get the same error after reinstalling driver then try to scan a document and
print from scanner without PC access. If you can't do this then follow the
roller of the scanner. If the light or the roller not moving properly then contact
nearest service center. You may need to replace the roller.
SOURCE: Have bought new Canon Laser Shot printer
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload : -
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
