I've tried using the 3 codes listed by Comcast for the Samsung LCD but none of them work to allow me to control the LCD (like volume) with the Comcast remote.
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
Code 10812 on Comcast OnDemand 3-Device works with LN46B550 as well
10812 worked for samsung 32a330. used with comcast dvr remote and motorola standard def cable box (not the high def one). i had good luck with other codes provided by comcast for magnavox and sanyo with HD boxes from comcast.
thanks for the fix!
I just solved my jer 323 programming and code problem for Samsung! Hold TV and OOn/Off at same time and hold until red light appears; then release both and press on/off at about 1 sec intervals until tv goes off. I only had to press on/off about 4 or 5 times.
Just installed a Samsung LN37A550 and used the Comcast Remote code 10812 and it works:
On the Comcast (OFA) Remote
1. press TV
2. press setup until the TV light blinks twice
3. Enter 10812
4. Press Power and the TV should turn on and off.
My Silver and Black DVR remote (stupid Comcast gave me an SD DVR though) worked perfectly with the 10812. The 0060 and 4 digit code idea are bogus. My remote could only change the volume by hitting Vol +/-, any other button, and then Vol +/- again. 10812 fixed my problem, 0060 made it worse.
Entering 10812 into Comcast remote to control Samsung LN40A650 works for me ! Thanks :-)
I have a samsung lcd series 5 550 tv. I cannot get the comcast remote to work with any of the codes given. Any suggestions? Thank you for your time and consideration.
[email protected]
I have a similar problem trying to program a Time warner DVR remote to operate my Samsung LN37A550 and also a samsung dvd player.
Time warner couldn't help and Samsung's FAQ said to go to the remote mfr for help(Time warner).
Any suggestions?
I have a 550 and none of the comcast codes work
With Comcast 3-in1 on Demand silver remote and Samsung 50" plasma, the 10812 worked. Requires 5 digits to make TV LED light blink twice.
I need the code for my Samsung CXD2512 TV/VCR combination unit to work with an RCA DTA800B1 digital converter box.
Same problem 40" samsung LCD
my new Xfinity Comcast remote will not program the volume or mute button on the comcast remote
comcast remote can't program to my Philips tv to make comcast remote work volume and mute controls
