Clean the intake components and check their operation. Excess fuel symptom. Mass airflow sensor, throttle position sensor, throttle body, intake air temp sensor, whatever else there is
black smoke is over fueling and although the turbo appears to spin ok the vale variation actuator may not be operating correctly
there are vanes in the exhaust turbine housing that are altered to increase the exhaust gas flow onto the turbine blades for quicker acceleration and these vanes are operated by a vacuum actuator and rod by a sensor
the vanes are subject to extreme heat and can rust stuck open or the hose gets hard and cracks
s not allowing the vanes to work
I would be concentrating in this area before the EGR valve
run the fault codes as well to get a better idea of the possible fault as some systems only put the light on for extreme conditions in engine and transmission
black smoke is excessive fuel in the air fuel ratio
causes leaking gaskets under injectors, problem HO2S sensor , blocked air inlet /filter, excessive fuel pressure
possible cause --mechanic did not use new gaskets under injectors that were damaged form the overheating
is it a diesel or gas engine?
Usually excessive blue smoke on start up indicates oil is getting into the combustion chamber. It could be piston rings or valve seals.
Quick check, drive it within operating range and speed. Either use the rear view mirror or get someone to drive it and you follow in another vehicle. Accelerate, then take your foot of the accelerator. Blue smoke under acceleration indicates piston rings / pistons. Blue smoke on deceleration or the "over-run" indicates worn valve guides / seals.
White smoke can indicate coolant in the combustion chambers / leaking cyl head gskt, or incorrect fueling. If brake fluid gets into the combustion chamber it will generate a lot of white smoke from the exhaust. However, that would entail a leaking brake master cyl and a leaking brake booster.
Sometimes diesel engines will put out black smoke under extreme acceleration. Other than that, they shouldn't smoke. Black is excess fuel, White smoke is water and bluish is oil. White smoke on a cool morning is not necessarily a sign of a problem unless it happens every time you start it through a warm day. Hope this helps.
