eMachines E620-5885 Notebook Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Might have been dropped, paart of the screen stays a violet color instead of changing colors with the image on the screen the image is that of dragon almost. The other thing I noted was I cannot get the index arrow to move to where I point it.
Matthew Gryzbek
Level 1:
  • Contributor 0 Answers
  • Posted on Dec 30, 2014
Matthew Gryzbek
Contributor
Level 1:
Answers
0
Questions
Helped
75
Points
0
Where can I get a screen for a dragon touch e70 7"?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Sep 18, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
0
Helped
70791
Points
949
Yeah its taken a pretty good hit, the screen has a broken ink cartrige, and the touch pad for the mouse has probably come unpluged from the mother board
Why do i have ugly color on my samsung 933bw om my first monitor i have blue logo of my windows but on my samsung 933bw i have violet color not blue
What happens when you change the monitors to the different ports? Does the violet monitor stay violet when it is plugged into the other video port?
I am guessing that the monitor that is violet is using a VGA connection
The most common cause of a monitor displaying a pink or violet color cast is that one of the RGB conductors in the VGA cable is broken, or the plugs are not firmly seated in the sockets, leading to one color not firing on the monitor. Try a different cable. Try plugging it in with DVI instead.
Can you change a Dragon Touch X10 screen temperature color from warm to cool?
Yes, it is possible to change the screen temperature color on a Dragon Touch X10 tablet. You can do this by adjusting the color temperature settings in the display settings menu. If your tablet does not have a color temperature setting, you can try downloading a third-party app from the Google Play Store that allows you to adjust the color temperature of your screen.
What do i replace koleston perfect 5/75 with ? i dont like red violet but i want to stay wit the same range
I have a couple questions. A: What is your natural color and do you have any gray?B: What is your target color? C: Do you want to be Auburn or more of a solid red?
1helpful
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
2answers
Ricoh Aficio 1232C prints with red-violet tone
download the RPCS driver from the Ricoh support site and then when you will install the driver go to preference then user settings and adjust the contrast and other options until you get the color of the printed image as you wish to be
Colors on the left side of the screen are shadowed with duplicate
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
2answers
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
