After taking the pictures, and looking through the selection that i have taken, all the white parts flash black, this also happens when i view them on the tv, Brand new camera, had this a week, im sure it is a set up problem but i cant find the solution
if u r getting green signal of flash charging,then discharging section is defective,sochaque the section replace the parts xenon tube etc or take it to a tech.
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
keep the camera in manual mode and increase ISO more than 800 and shutter speed should be low , for black &white picture go setup in pencil mark & go to black&white option
Highlight is just the info mode, there are several info modes including Basic file info, Shooting Info and RGB histogram, just press the round controller in the up or down direction to change between them in playback mode. Highlight will flash black anywhere there is pure white in an image. Try resetting the camera by pressing the 2 buttons with green dots (on top of the camera near the shutter release) holding them for a few seconds.
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
Hey mcgeedds, What you’re seeing is probably what is called digital noise. At low levels of light the sensor in the camera that records the image shares data from one pixel to the ones adjacent to it which causes digital noise. The way to fix this is either make sure your noise reduction setting is turned on, or get a powerful off camera flash that has the power and coverage capabilities to light the subject at the distance you are from your subject. Noise reduction on average should double your exposure time requiring you to use a tripod in most cases. Also pay attention to your iso setting if it is too high this can also cause digital noise in your images. I almost never shoot with a higher iso that 400. I hope this helps. Sincerely, Allan Go Ahead. Use Us.
