Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
My Rheem is a 82V40. It keeps popping the circuit within 30 seconds after it is reset. Water heater is approximately 5 1/2 years old and I do not think the tank has ever been drained.
    Genius:
  • 1,273 Answers
To add to the first solution, You must drain the tank before you replace the elements. Especially the bottom element. The tank has two elements similar to the elements in an electric stove along with two thermostats that control the temperature of the water If an element(Calrod) is burned in half then the water acts as a resistor increasing the amp drain that pops the circuit breaker. Cut the power to the W heater at the breaker box. Using a meter check for power on the elements, no power drain the tank. Check for continuity on the elements. This should tell you what element is bad.
Posted on Sep 19, 2010
  • 455 Answers
Hello,You have a shorted heater ELEMENT.They can be eaisly replaced.Draining the tank will not slove the problem.
Posted on Sep 18, 2010
Testimonial: "I thank you for your solution. I wanted to see if I Rheem water heaters possibly had a common problem. The easiest solution is usually the best. "
SOURCE:
My water is not getting hot I have a Rheem model # 82v40-2
take off both front doors on heater,one of them will have a red reset button,press it,it should heat now,if it happens again,you will need new elements
Mar 28, 2015 | Rheem Water Heaters
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Can i use a thermal blanket for my Rheem Glasfury 82v40-2 hot water heater
Modern water heaters are well insulated to the point that adding additional insulation is not beneficial. Some units may also suffer from a blanket blocking air vents or causing condensation build up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Dec 31, 2012 | Rheem 82V40-2 Fury Electric Residential...
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
Suddenly stopped heating water
Check the top thermostat2_bing.gif... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
242 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
