1.
On your laptop turn ON the wireless switch, it
may be on the side or in front. 2.
After turning ON the wireless switch the
wireless light will turn ON 3.
Click on "Start"
and click on "Run" type "ncpa.cpl" and click "OK" 4.
"Network
connections" window will open 5.
In "Network
connection" right click on "wireless
network connection" and left click on "view
available wireless networks" 6.
You will get a window showing all the wireless networks in range 7.
Click on the wireless network you want to
connect to and click "connect" 8.
If it is a secured wireless network you will be
prompted to enter the password or else you will be connected directly 9.
If it prompts you for a password, type the password
and reconfirm the same in the 2nd box and click connect. 10.
After a
few seconds you will be connected to the wireless network.
I have the same problem with my Acer Aspire 4520. There is a button at the top of the keyboard to turn on the wireless LAN but it says "wireless LAN disabled". I can't figure out how to turn it back on. Nothing in Control Panel helps. What is the problem??!! Please help!
The operating system was not defined in this answer and so is not helpful to those with other than this specific operating system, whatever it is.
Locate the Wireless LAN switch located on the front of your Acer Notebook.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Connect."
or
Power on the Acer Aspire laptop.
Right-click the wireless Internet icon in the lower right corner of the desktop.
Select "Enable" from the pull-down menu.
Right-click the wireless icon again.
Select to view all available wireless networks in the area.
Momentarily a window appears with all of the available Wi-Fi networks.
Select the Wi-Fi network you want to connect to, then type in the password (if required).
Click "Connect," and your Acer Aspire computer connects to the Internet.
hope this helps
· 3 Press the "Fn" and "F2"
keys simultaneously to turn on the wireless connectivity option for your Acer
Aspire One. You may need to press these keys several times until the light
above the wireless symbol glows orange.
· 4 Click the "Wireless Network Icon"
in the system tray at the lower right corner of the screen. This icon looks
like a computer with semi-circles next to it.
· 5 Select the SSID of the wireless network
that you wish to connect to, then click the "Connect" button.
· 6 Type the security key for the wireless network when prompted, then click "Connect."
