Question about HP Compaq ProLiant DL380 G4 Server
Redhat es5 seems that the redhat installation procedure can't recognize dl380 G4 as a 64 bit machine. (after installation there is no /lib64 nor /usr/lib64). Is it neccessary to configure something specific in the installation stage that refer to this issue?
    Problem Solver:
  • 5 Answers
OS Supported by DL380 G4 According to HP website are : -
» Microsoft Windows 2000
» Microsoft Windows Server 2003
» Microsoft Windows Server 2003 for 64-bit Extended Systems
» Microsoft Windows Server 2008 W32
» Microsoft Windows Server 2008 x64
» Novell NetWare 5.1
» Novell NetWare 6.5
» Red Hat Enterprise Linux 2.1 (x86)
» Red Hat Enterprise Linux 3 (AMD64/EM64T)
» Red Hat Enterprise Linux 3 (x86)
» Red Hat Enterprise Linux 4 (AMD64/EM64T)
» Red Hat Enterprise Linux 4 (x86)
» Red Hat Enterprise Linux 5 Server (x86)
» Red Hat Enterprise Linux 5 Server (x86-64)
» SCO OpenServer 5
» SCO OpenServer 6
» SCO UnixWare 7
» Sun Solaris 10 x86 Platform Edition
» Sun Solaris 8 Intel Platform Edition
» Sun Solaris 9 Intel Platform Edition
» SUSE Linux Enterprise Server 10 (AMD64/EM64T)
» SUSE Linux Enterprise Server 10 (x86)
» SUSE Linux Enterprise Server 8
» SUSE Linux Enterprise Server 9 (AMD64/EM64T)
» SUSE Linux Enterprise Server 9 (x86)
» VMware ESX Server 2.5
» VMware ESX Server 3.0
so DL380 G4 does support 64 bit OS :
There are no Setting in the BIOS as such . no special settings need to be changed.
lib32 is for 32-bit and lib64 is for 64-bit obviously, If you are using a 64bit OS and these folder doesnt show then installation did not happen properly.
It seems more of a OS CD Issue . Erase the HDDs again , configure raid . use a known good RHEL CD to install .
Hope This is Helpful.
Cheers :)
Posted on Jun 05, 2008
This model was found not to be 64bit but 32bit.
Posted on May 19, 2008
SOURCE:
Wont copy paper
The Brother Linux scanner driver works only with a superuser by default.
To use it with a normal user, you will have to make some settings.
Setting for normal users
http://welcome.solutions.brother.com...1c.html#u13.04
There is also an installer glitch when installing on 64 bit systems. I don't know if it's been fixed or not. Here is the Brother info
You'll need to scroll down a bit to find the appropriate brscan version. I think the 430 uses brscan4 but I'm not certain.
Install the scan driver.
Copy the following files under /usr/lib64/ to /usr/lib/
For brscan4 Users:
/usr/lib64/sane/libsane-brother4.so.1.0.7
/usr/lib64/sane/libsane-brother4.so.14/ to /usr/lib/.
http://welcome.solutions.brother.com...cn.html#f00106
You'll probably need to restart after applying these fixes.
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother FAX Office Equipment & Supplies
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
Is there any procedure to boot DL380 G4 in single mode ? Thanks
Connect the keyboard, mouse, monitor, network cable and power cord. press the power button on the front panel of the server. If the OS is installed the server will boot.
May 17, 2010 | HP Compaq ProLiant DL380 G4 Server
Is there a BIOS setting on the DL380 G4 that needs to be changed to allow it to boot from DVD?
Please check in your BIOS and see if that "Function" is available, usually it is. Otherwise it makes it real hard to do anything. However what we used to do in "The Old Days" in a machine that didn't, was to do an install on another very similar machine, also place on it, ALL necessary "Drivers" for the actual machine you will be using & transfer to a Directory, on the new machine. Then on the new machine, at FIRST Bootup, boot in SAFE MODE and Rip all the Drivers out of Device Manager, and reboot, NOW it will detect the new hardware and ask for Drivers, point them to the place you had prepared for them and Install. A bit of work.. but gets there in the end. Don't forget USB Flash Drives as well.
Feb 13, 2010 | HP Compaq ProLiant DL380 G4 Server
I have a compaq DL380
You can use one with data on it since the drive will reinitialize itself and level the data back onto it from the non failed drive.
May 04, 2009 | Compaq ProLiant DL380 Server
Configure Huawei E220 for Redhat 9
well depends on what u want to do, if u want to wipe out your old os and install redhat on the hdd, or you can dual boot, or you can use vmware to create a virtual machine. heres a website i thought would be useful, http://www.redhat.com/docs/manuals/linux/RHL-9-Manual/install-guide/index.html
Apr 24, 2009 | Acer Aspire One PC Notebook
HP Compaq ProLiant DL380 G4 Server Logo
572 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
