Hi. I guess there is something wrong with youe router. Normal operation is you dont need to reboot the router just to keep the connection on you computer. Try to hard reset the router first and observed. If same issue occur then try to upgrade the firmware. If same thing will happen after doing all this. Then this could be a router problem. might be some of the chips inside the board is failing.
All the best!
i do not see the solution you said that i would find when i clicked on the buttton you indicated
