Technics SL-1210 Turntable Logo
Posted on Sep 17, 2010
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help please?
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
11175
Points
61
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Hi there, I have just replaced faulty rca's on my
Possible internal damage on the unit, please replace back with the old unit to confirm if the connection pins and wiring are working. If so you need to check with a new unit.
WHEN I TRY TO USE ANY ORTOFON CARTRIDGE I GET FEEDBACK WHEN I PUT IT ON THE TONEARM BUT ON MY TECHNIC 1210 IT DOESNT HAPPEN BUT IF I USE ANY STANTON CARTRIDGE IT IS FINE? WHY WOULD THIS BE? ALSO THE...
I'd fix the tonearm issue first before using it to decide you have a feedback-related issue with one brand of cartridge. I can't say how that would be fixed.
Feedback? Like airborne sounds from the speakers vibrating the turntable and being amplified through the speakers? The biggest downside to old-school vinyl use is that possibility and the workarounds we had to use to prevent it. Acoustic and physical isolation are the only solutions.
2helpful
3answers
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Humming Noise from satellite speakers
noise can be generated since dust in the jack connector of your PC, bad sound card or belive or not, the socket. try to unplug another devices and leave alone the x240... compare.
3answers
Thump or thud coming from speakers when turntable is tapped
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
2answers
Sound problem
first thing to do is take the left and put in in the right, do you get sound on the right?
now take the phono cartridge wires and move the left to the right and right to the left does the sound move or stay same place. if they move with or not tells you if the cartridge is bad or phono plugs. if they dont move it's the phono plugs if the does move it's the cart.
1helpful
2answers
Some sounds are lower in songs
Well, it seems you answered your own question. Replace your stylus. If that doesn't solve your problem, the issue might be your RCA cables or tonearm.
What many people don't understand is that it takes ALOT to wear out a record. I mean, you would have to play a record about a good 1000 times before you'll see any sort of real wear/tear on it. Why do you think they last so long? Besides, record wear doesn't sound like that. With TRUE record wear you'll experience lots of skipping from your stylus, as the grooves have worn down. Also, you'll get alot of pan issues, where the sound goes in/out left/right side. The grooves of a record are a V shape, and the left side of the V carries the left signal, and the right side carries the right signal. With record wear, usually 1 side will wear out quicker than the other, and that's why you'll get inconsistencies with sound.
Unless you play the same record over and over again for the past few years, you wont see this kind of wear.
Replace your stylus first, then have your RCA cables and tonearm checked. Try cleaning out your tonearm with 99.9% PURE ISOPROPYL ALCOHOL and see if that does anything.
Good luck
DJ PRO LAB
Feedback humming noise
This is a tonearm issue. Your tonearm probably has a loose ground connection, or if you moved it recently, may have been damaged in transit. Also, try and move your turntable to a different location in the room. If your near any serious power source (light dimmer switch, microwave, frig, etc), it will only amplify the issue. But other than that, it sounds like a common tonearm issue, and you will need to have your tonearm replaced.
- TWEAK AV LAB
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
