Rebuild carb.needle is not seating
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
