When I do the auto set up it give me an error on the last left speaker. E-6 Check SUR.
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
Hi there I have a few month old onkyo TX-sr309 I can get sound on iPod input can get no sound on fm Fm is tuned to station tuned highlighted. But no sound Please help I love my radio!
Now that you've checked the surround speakers, (You have, haven't you?) you have probably got a defective driver/output on that channel in the receiver...accordianman
I've got the same problem on an RXV1800. Its a 7.1 amp but I've only got 5.1 speakers attached. I only get this message when trying to do the auto-setup. I've got hardly any sound coming from the rear speakers. The trouble shooting guide in the owners manual says this error happens when you don't have the surround side speakers connected. The only suggested remedy is connect the two side speakers. This is unhelpful since I only plan to run 5.1.
