SOURCE: Laptop LCD won't display
Bad Video.... It is replaceable if you have dedicated Video,
Need to replace the motherboard if you have onboard (integrated)video..
SOURCE: Toshiba TE2100 blank laptop screen
You have a either a bad inverter (which lights the screen's tube) or a broken tube. that'd be my guess.
Try this: shine a bright light on the screen from the side - if the light is hot be sure not to be too close or the screen will melt - and see if there's any image on the screen. There should be...
SOURCE: I have a Toshiba Satellite A305D-S6848 For a
I. Reinstall the driver:
Right click on My Computer (XP)/Computer (Vista) icon on the Desktop, click on Properties, the on Devices, then in the devices list look for your camera (you might have to open the branches to see it). You may find it under a branch named ‘Image Processing Devices’ or something similar (I don’t know the exact wording, because my system is not English).
Select your camera entry and then double click on it. Under the Driver tab, select Update driver and choose Reinstall Driver and then the second option ‘Look for Device Software in the Computer”.
II. If that doesn't solve your problem, download and install the most update driver from TOSHIBA support pages:
SOURCE: Toshiba Satellite A305D-S6848 will not keep
just update the BIOS it will help or else check with the physical connection if u find any damage contact the vendor..
