Thought I knew the 4 number combination, now locked inside. I do have the key. However, safe not opening. What is the exact procudure for combo?
    Brigadier General:
  • 3,006 Answers
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Posted on Sep 17, 2010
SOURCE:
I have a master lock safe space p19919. I changed the code yesterday, now im unable to open box. tried many combos to open, no luck. Is there a reset code to change combo ? thanks Dave
No, because if there was a master reset code, every burglar would know it, making the safe worthless. Bolt croppers or a disc saw.
Masterlock.com Official Site ' The Master Lock Company‎
Adwww.masterlock.com/‎ Manufacturer of Locks, Safes and Security Products for Home & Business
4-Dial Combination · Custom Laser Engraved · Push Button Combination · Limited Lifetime Warranty
Highlights: Founded In 1921, Offer Security Solutions...
Search Results
[PDF]Operating Instructions:
content.masterlock.com/masterlock/.../5422D_Instruction_Sheet.pd... Translate this page
Open lock box and locate the yellow ... Save your combination in a safe place .... Master Lock Company LLC, Milwaukee, WI 53210 U.S.A. ' 800-308-9244.
5900D Set Your Own Combination Portable Personal Safe - Master Lock
https://www.masterlock.com/personal-use/product/5900D US$28.69
The Master Lock No. 5900D SafeSpace® Portable Personal Safe features durable construction made to withstand abuse and is water resistant. The safe measures 2-1/5in (57mm) H x 9-2/5in (23.9cm) W x 5-1/10in (13.1cm) D; and is ideal for recreation, campus, office, travel or leisure use.
Service and Support - Videos: Lock Boxes ' Master Lock
? 2:20
https://www.masterlock.com/service-and-support/.../lock-boxes
Uploaded by Master Lock
The Master Lock SafeSpace® Lock Boxes provide secure storage of keys or access cards in a convenient ...
Master Lock 5422D & 5423D Push Button Key Safes - YouTube
? 2:53
https://www.youtube.com/watch?v=36L3ABIG2TE Feb 19, 2014 - Uploaded by The Lock People
Master Lock 5422D & 5423D Push Button Key Safes ... This Master Lock key safe lock box allows for ...
May 13, 2018 | Master Lock Locks & Locksmithing
Why won't my safe open? I have 3 keys that fit, door won't open . I don't know combination.
There should be a serial number on the safe. You can google the manufacturer and get a contact number, call them and they will be able to walk you through resetting the combination. But it sounds like you will need to replace the battery in it first
Dec 02, 2014 | Home Security
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
Locked safe
I have a s0409 safe,I have the key but lost the combination to it,what do i do,it has numbers ah-447659* sticker on it.
Mar 18, 2010 | Schylling Combination Steel Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Mar 16, 2009 | Sentry Fireproof Safe
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
Open Questions:
197 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
