Compaq Presario 5000 PC Desktop Logo
Anonymous Posted on May 17, 2008
Pixels change when I start computer
When I start my computer each day, the pixels will change to 640 by 480. I use 800 by 600 normally. It starts normally, then the screen will go blank for a few seconds, and then it goes to 640 by 480 pixels. I have to right click on my desktop, and reset settings back to 800 by 600 pixels. This just started about three days ago. I ran my anti-spyware, and anti-virus programs, and they found nothing. Could you please help? Thank You.
  • Anonymous May 20, 2008
    Thank You Very Much!!
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
  • Posted on May 17, 2008
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879173
Points
3834
Try updating your video driver.
  • Georgia B
    Georgia B May 20, 2008
    Glad to hear you got it fixed.
    Thanks for voting.
Colorful lines wont go away
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
How to adjust color of screen
click start control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
click start control panel,display,desktop you can select a different desktop from the drop down list also there should be a browse button where you select your own personal picture saved in my pictures also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope it helps
Dropped my notebook and pixels are messed up, is there anyway to repair?
hope this helps you
I have Intel DG33FB motherboard, 2gb DDR2 RAM, Nvidia 8600GT graphics card.In few days my computer start with something Different Pixel color.After 5 to 10 miniuts letter my screen color blink with yellow...
The problem can be possible with RAM's print and with graphic chip so when you change the ram but problem will be remain same then you should change your graphic card. I hope you will fix your issue easily.
Thanks
How do i zoom out on my computer
more or less pixels
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps
My video card, which has a sticker with the Letters and numbers REV A02 appears to have gone bad. When I start my computer, all is fine until it gets to the login screen, at which point the display gets...
also
hope this helps
My computer is changing his contrast by itself what should i do?
don
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Dell m170 pixelated screen on start up will only boot up safemode
The video card could be going out, this happens alot where i work. Are the pixels that are out always in the same spot or does it change as you navigate around windows?
If the pixels are always in the exact same place, its the LCD, If not, its the video card.
Be sure to have the proper drivers, get any updates from www.support.dell.com. select the model number or enter the TAG number off the back or do search for DELL M 170 or Latitude M170 or whatever model it is.
Try this out and if no go, then get back to me.
Good luck
2answers
(what appears to be) color pixels on computer screen
try a different video card , if you have one.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
