Question about Dometic Rooftop RV Air Conditioner
Duo-Therm by Dometic Thermostat
We are trying to wire this back up. Can you help?
  • 1 more comment
  • burton_mc Jul 27, 2008
    I have a new duo-therm dometic thermostat to replace my existing duo-therm thermostat. Both units have 6 wires on them but the directions have have for the new one don't match the labels and colors on the old one.
    the old one has the following colours and labels
    RH - red wire (that goes to the furnace)
    W - white wire (that goes to the furnace)
    G - green wire that is a ground (part of 4 wires that go to AC)
    RC - red wire that has +12 volts (part of 4 wires that go to AC)
    Y - white wire that is part of 4 wires that go to the AC
    H - blue wire that is part of 4 wires that go to the AC
    I used a meter on the G and RC wire to verify that I have power
    Below is the instructions for the wires for the new thermostat
    HI-FAN - blue wire
    GND - black or green wire
    FAN - orange or tan
    COOL - yellow
    FURNACE - white
    +7.5 - red or red/white
    with the old thermostat the AC works but the furnace does not start at all....I replaced the relay on the furnace because if I bypass the relay the furnace motor does run...just replacing the relay didn't make the furnace run so I decided to get a new thermostat
    when I replaced the thermostat with the new one I used the following wiring but then nothing worked (not even the AC) - so I need some help wiring the new thermostat
    HI-FAN - the blue wire (H on the old one)
    GND - green wire (G on the old one)
    FAN - red wire (RH on the old one....I don't think this is correct)
    COOL - white wire from AC (Y on the old one)
    FURNACE - white wire from furnace (W on the old one)
    +7.5 - red wire from AC (RC on the old one)
    The old duo-therm by dometic has part number 3105058....if that helps at all.
    thanks
    Mike
  • Anonymous May 16, 2009
    I am trying to wire up a duo therm 3105058 A/C thermostat in an rv I recently purchased. The wires are no where near the color as listed in the earlier responses. They are 1 red , 1 white, 1 green, 1 light grey, 1 dark grey, & 1 blue. Does anyone know who to wire this up? The old one was already removed.
  • burdicda Aug 18, 2012
    I looked everywhere for clarification on this mod All the tips have RW + RC jumpered with a "BLACK OR GREEN" wire ground going to them....that didn't make any sense electronically to me so I put together a schematic diagram and just installed the mod last night...it works perfectly in cool, heat, fan speeds, everything.http://burdick.home.digital.net/ke4ozd/R... RC and RW are unjumpered in mine since each could theoretically have a different power source, otherwise you could be working on one alone and the darn thing energize on you from the other units power source.
    New Friend:
Red and white are positive and neg 12v
green is low fan
grey is high fan
yellow is cooling
blue is neg 12v(marked B-)
Posted on Sep 13, 2011
  • 828 Answers
Generally on most thermostats R is the power to the thermostat, W is for heating, Y is for cooling, and G is for fan operation.
Posted on May 31, 2008
    New Friend:
http://burdick.home.digital.net/ke4ozd/RVstat.jpg
Posted on Aug 18, 2012
    New Friend:
I am installing a therm from the old duo therm need the wiring diagram for the new one blue , y, white, bro, org where do they go
Posted on Apr 20, 2010
SOURCE:
We have a Duo-therm by Dometic thermostat that does not shut the ac off. We have to manually shut thermostat off to shut ac off. Any suggestions what we can try or just replace thermostat?
Try plugging the hole in the wall where the wire comes through. Also be sure you are not trying to reach your humidity set point therefore overshooting your cooling setpoint. Referred to "droop" in settings
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 01, 2017 | Dometic Heating & Cooling
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
I am trying to hook up a gfi with a piolt light switch , when i connect and try it i blow the fuses help
Unfortunately, you don't say what wires are inside box or what lights you are connecting, or what type of switch you are replacing.
So here is generic explanation, You can add comment with more information for more free help.
Back of wiring device are markings that show Line and Load.
There are 4 screws. One brass and one silver screw for each Line and Load.
On back of device are two wires that stick out. These wires go to Black and white wire going to your light.
Electricians don't guess, they test.
Separate wires for testing
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
Hot wire connects to Brass Line screw.
If there is another black wire that was connected with Hot wire, then this wire connects to Line brass screw.
Hot wire is identified.
Test Hot wire to each other wire, except bare ground.
Tester lights up on Neutral wire.
This wire connects to Silver Line screw. Pilot light will come on each time switch is moved.
If Neutral wire is wrapped together with other wire(s), then this wire is a) the white neutral for light, and connects to one of wires sticking out from back of gfci. Or b) this wire is a neutral and connects to silver Load screw.
Add a comment for more free help, and say precisely what wires and lights you are connecting, and what type of switch you are replacing.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
Dec 20, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Dometic Rooftop RV Air Conditioner Logo
9,466 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
