Overheating is considered as one of the major causes of shutdown problems in laptops.
When any laptop runs, it generates heat and if it does not cool down, it may result in random shutdowns.
Thus, to get rid of this issue with your HP laptop, you should keep it on a flat surface and allow the fans underneath to work.
The use of cooling pads for laptops is also recommended.
This helps in removing the excess heat.
Get more information to fix HP laptop shutting off issue :
http://supportforhp.iyogi.com/laptop-keeps-shutting-off.html
Hope this information helps you.
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
SOURCE: AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
SOURCE: hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
