Cause
Any of the following issues can cause this issue:
The paper trays are empty or overloaded.
The paper is curled.
The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
The paper is too slick for the product.
The paper might not be engaged with the feed rollers.
The paper-width guide is pressed against the paper stack too tightly.
The paper tray is not completely inserted into the product.
The paper settings in the print driver do not match the paper loaded in the paper tray.
The rubber paper-feed rollers are dusty.
Check the media and print settings
a)While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
b)If the printer is not already on, turn it on by pushing the power button.Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
c)Verify that all the paper is the same size and type.
d)Tap the stack of paper on a flat surface to align the edges
e)Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
f)Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
g)Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1.Open a document in the application in which it was created.
2.Click File
3.Click Print
4.Click Properties . The Printer Properties dialog box displays.
5.Click the Paper/Quality tab.
6.In the Size is drop-down menu, select the size of the paper loaded in the unit.
7.In the Type is drop-down menu, select the type of paper loaded in the unit.
8.click ok.
9.On the Print dialog box, click OK to print the document.
10.Try printing again.
If the issue is not solved, try next steps
1.Turn off the product and unplug the power cord.
2.Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door.
3.Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
4.Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5.Close the access door and plug in the power cord.
6.Try printing again.
SOURCE: i have a samsung SCX 4824 FN printer- message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
SOURCE: Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
