This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
