I bought an Acer Aspire 1410 laptop and to start, appears error "primary master WDC WD1600BEVT-22ZCT LOCK. Enter Unlock Password(Key: 60324992)". Please help me!
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
There are several ways. If you have made a password disk use this. Most users do not so you can go online and download a password cracker tool and that will work. You could also do a recovery and that will set it back to factory settings but you will lose all your data Good luck!
Sounds like there is a password on your hard drive. There really is no way around this. If you cannot remember the password, you can send if off to some specialized companies, but it cost a lot of money.
You need to log into the bios and edit the hdd password... You can press DEL or F2 key when you power ON the laptop... It will take you to the bios setup... You can navigate in the bios to reach the hard drive password section and you can set the password as blank... Once you are done press F10 to save the changes and exit out of it...
If it doesnt works, then you can give a try by restoring the BIOS to its factory defaults(using the restore defaults option in bios) which should turn OFF the Bios HDD security feature...
This error has something to do with your BIOS settings, so what we need to do here is to check BIOS and to do that follow this. You can access BIOS by restarting computer and once you hear the beep code continuously press DEL key and that shopuld load up the BIOS menu then once you're there just have to go to bios and detect my primary master and save the configuration. But if that wont work on the last tab or on the advance tab on your BISO look for a option to reset or restore BIOS to its default settings and then save it and after that everything should be fine.
This is a suggestion but may work. Try to get into the bios and edit the hdd password. I believe you either press DEL key when you power on the laptop or it might be F2, not quite sure. You will have to navigate in the bios to reach the set hard drive password section. Set to blank password and see if it allows you to boot.
When i start my lap it asks for wdc wdc3200bpvt-22zes
