A couple of suggestions: Make sure that the gasket seal is good between carb and engine. I had a similar problem with my Cat 500 and found that the choke was sticking. I sprayed down the carb with Gunk and made sure all moving parts were not hanging up. I also put anti fogging oil in the gas to help clean jets and ports hard to clean with a carb rebuild.
If you are using an imported file, file names must be under 8 characters and have no spaces. Please be sure to delete the converted .DAT file, rename the original .CSV according to these rules, then convert the .CSV to .DAT.
You probably have a bad clutch seal on your crankshaft, or one dirty carburetor, or possibly bad spark plug caps. Clean your carburetors, change your plug caps, and test drive the machine carefully. If it still bogs , buy an after market piston kit with crankshaft seals, gaskets, pistons, and rings. Do a complete rebuild it should only cost about $150 for all the parts in a kit. Then you should be good to go for another 17 years.
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
that is a (your firmware is a official firmeware)you cannot run any software like umd dumper you shoud have custom firmware
if you want custom firmware
if you a fat or slim and light psp you aree in luck you can make or buy a pandora kit and downgrade from any firmware if you are using psp go u cannot have psp custom firmware although the dark alex(creator of m33)is finding a way to make custom firmware in psp go
and if you have psp slim and brite you cannot make the custom firmware yourself you may consider giving it to a game store for custom firmware
thanks rate 4 thumbs i helped you naa
Ford Lift Cover Repair Kit (770) $10.00 Ford Lift Cover Repair Kit. Fits 500 thur 4000 . Repalces: 3B5564
depending on year of your tractor it takes a rebuild kit, assuming your cylinder and ram are in good shape and free of rust, nicks and scratches, if the ram is damaged a new seal kit will be shortlived, its pretty straing forward repair, the only thing you may need is an adjustable spanner wrench set to remove the endcaps hope this steers you in the right direction
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Thanks.
