Connect by this way:
1. S-Video - This is probably the most common method
out there currently because an S-Video cable is cheap as heck and just
about every TV under the sun has a S-Video port. You'll have to make
sure you laptop is equipped with this port. Remember, there are two
types of S-Video cables: 4-pin and 7-pin. Most laptops
and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin
S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better
off connecting using a VGA cable. It gives much better quality than
S-Video and as with S-Video, the cable is very cheap. You usually won't
find a VGA port on regular TV's though, so this option is if you have an
HDTV.
3. DVI - DVI stands for Digital Visual
Interface with "digital" being the key word there. The digital
signal will give a higher quality picture than either S-Video or VGA. Of
course, your computer will need to have a DVI connection and your TV
will need to be an HDTV. This cord is definitely not cheap, it ranges
anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality
by far. No computers that I know of yet have HDMI ports, but you can get
a DVI to HDMI cable to connect it to your HDTV. HDMI is
compatible with DVI.
5. Scan Converter Box - This is the last method that
I could think of and it involves using a scan converter box, which
takes a VGA signal and converts it into S-Video or component video.
