Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
SOURCE: setting low pass and bass eq
the only thing that might damage equiptment other than playing it too loud would be running at 1 ohm if not supported by the amplifier.
as far as the eq and crossover settings, that is dependent on personal preference, and the acoustics of the paticular vheicle installed
SOURCE: Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
SOURCE: sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
