Fusing drive motor failure, replace the fuser recently? (THE HOT PART) there is something jammed the fuser can't turn, orange looking rollers about 12" long, on the right side of the machine. above the transfer belt. Hopefully the motor is not burned out worse case the moor is burned out and that took the control board $$$$$$$$$$$. Open close the front door to reset
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
