Nortel T7316E 2-Line Corded Phone Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have T7316E. want to replace the set with another set. How do I keep the same extension number? Thanks
george peters
Level 3:
President:
  • Nortel Master 860 Answers
  • Posted on Sep 16, 2010
george  peters
Nortel Master
Level 3:
President:
Answers
860
Questions
0
Helped
609315
Points
3471
Providing set relocation isn't turned on in programming, changing one phone with another will not change the extension number at that location.
I have nortel set T7316 i have tried featues 985 and than its not give me an option to enter 9 nad password i enterd that 73738767793 but it keep sayin invalid password
The 9 option is not offered verbally but it exist. Press the 9 and then enter the 73738767793 at the Pswd prompt and answer the Reset pswd question with YES. The administrator password will be reset to default which is 120000 (2 digit extensions numbers), 1020000 (3 digit extension numbers), or 10020000 (4 digit extension numbers).
Hi we have a Nortel T7316E. Staff change their
Hi Amy, you can change the name for an extension, but it will change the name for the extension for all the phones.
It is best to do programming on a T7316, M7310, or an M7324
1. Feature **23646
2. Password: 266344
>>>your password may have been changed by your phone company. contact them for the password.
3. Scroll to General Admin
4. Go to Names
5. Select Set Names
6. Enter in the DN of the extension you would like to change
7. Use the dial pad to change the extension.
8. Press Rls when finished (handset with arrow facing down)
4helpful
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
1helpful
3answers
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you your mailbox extension
How to move extension numbers from office to office using nortel t7316e
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
2answers
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
4helpful
How do you get a t7316e phone to ring
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
2helpful
My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
16helpful
3answers
Change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
