Question about Kitchen Ranges
How do I take the back panel off to get into where I can change the termal fuse?
    Genius:
  • 1,417 Answers
HELLO,
Please follow the bellow instructions
1.Unplug your microwave. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
2.Locate the fuse. It should be near where the electrical cord comes into the microwave. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the microwave.
3.Purchase a new fuse. Most Panasonic microwave ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
4.Replace the fuse. Put the cover back on and see if your microwave works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced of professionally repaired.
Thank and thanks for using fixya.
Posted on Sep 15, 2010
SOURCE:
Dryer will not heat when using any of the heating cycles.
first check element, then is it isnt broken check safety fuse on element assembly for continuity theres an other termal fuse right of the fan assembly all accesible with the front panel off
Feb 22, 2015 | Kenmore Ap4327152 Motor Control Board for...
How do yu take the back panel off of a kenmore 80 series 110.64892401
You really shouldn't remove the back panel yourself. If you are having a problem, contact Kenmore and see if it's still under warranty. If it is, then they will send someone out to do it, and you won't void your warranty doing it yourself. If it's no longer covered, your best bet is to call a repair shop, and see how much they would charge you to fix it.
Mar 05, 2012 | Kenmore Dryers
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
Ribbon in Printer Idle error
xgech if using ribbon, change the seting to Direct termal, if not, change to Termal transfer. save,(press 2x the enter button) restart the printer
Nov 05, 2010 | Zebra S4M Thermal Label Printer
Lable print ran out for paper and will not go back to normal. The lights on top are all on except Data , and is blinking Error Condition, Print Idle, Error cleared head open on the screen.
check the setings, change the setings, Media TYPE from Termal Transfere to Direct Termal.
if necessery, reset the printer to Factory Defult.
Mar 31, 2010 | Zebra Z4Mplus Label Printer
Will not heat
Check your house fuse/circuit breaker panel. The dryer runs off 2 circuits -one for heat and one for the motor.
Mar 14, 2010 | Dryers
DRYER HAS NO HEAT AND I WANT TO TEST THE HEATING ELEMENT BUT AM NOT SURE HOW.
you should be able to remove the back panel (after unplugging the AC power!) to see the coil under the barrel. You can use a multimeter set to ohms to measure the resistance across the 2 connectors of the coil, will probably need to unplug the connection to get accurate ready. If the resistance is infinate, the coil is bad.
However it is more likely that the termal fuse has blown rather than the element itself being bad. Follow the connectors up to find it, it should have 0 resistance if still good, infinite is blown.
Termal fuses have spring loaded contacts inside held in place with wax. If the tempurature gets too high, the wax melts allowing the contacts to separate. They can't be reset but replacements aren't expensive.
If the termal fuse turns out to be the problem, check the vents for lint build up or other restrictions. (Both inside the dryer from the filter on, and the external hose going outside.) Restictions on the exhuast can cause the heat to build, and is a fire hazard as well.
Mar 07, 2010 | Whirlpool Dryers
How do we get to the termal fuse on a maytag dryer
hi yES IT COULD BE THE THERMAL FUSE . tWO SCREWS AT BOTTOM OF DRYER REMOVE FRONT PANEL tHETHERMAL FUSE IS LOCATED ON THE AIR VENT TO THE LEFT OF THE ELEMENT . THANKSFOR THE QUESTION THE APPLIANCE DOC
Jul 25, 2008 | Maytag PYE2300AY Electric Dryer
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Alg643raw gas dryer
try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Mar 31, 2008 | Amana ALG643RB Gas Dryer
Kitchen Ranges Logo
318 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
