Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Posted on Sep 15, 2010
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 16, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
9335
Points
13
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
2answers
I have window server 2003 OS and 500 GB free agent desktop USB hard disk is not showing in my computer. So how can i rectify it?
I just finished a Chat exchange with Seagate Tech support. MS Server OS's are not supported for FreeAgent devices.
It appears that whatever drivers exist in the XP install that recognize the USB device connection are not the same in the MS Server environment.
I plan to check the USB device drivers from both systems and see if the XP USB device drivers will work on Server 2003.
Hi, My desktop does not respond to segate 320GB external Hard disk on windows server 2003 operating system. But it works fine in windows xp . Can anyone suggest me how to solve this . Thanks in...
It must be some driver problem.Try updating drivers through windows update or you can also try installing latest service pack for Windows 2003 Server.It will definitely solve your problem.
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
1helpful
Describe your officejet 4355 drivers for win 2003 server Problem Cannot install it on Windows Server 2003.. Please HELP...
Hi! I will be glad to assist you in this issue:
Base on the operating system requirement for your printer. Here is the list of the operating system that support and does not support
Microsoft Windows 98 SE, Me, 2000 Professional Service Pack 3 or higher, XP Home, XP Professional, XP Media Center Edition, XP Starter Edition and Tablet PC Edition (does not support Windows 95, 98, 3.1, NT 4.0, DOS, 2003 Server, or Windows Vista editions).
here is the link for documentation of HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00615491&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1138373
4answers
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Freeagent with server 2003 not working
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
1helpful
Trying to install FreeAgent GO 500G as backup for Server 2003
Installation isn't possible directly from the Harddisk.
Try download from http://www.seagate.com/staticfiles/support/software/FreeAgentCN.zip
Good Luck.
Uwe
46helpful
8answers
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
2answers
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
