Xerox DocuColor 12 Printer Logo
Anonymous Posted on Sep 15, 2010
System fault code 10-389 won't clear - Xerox DocuColor 12 Printer
  • Anonymous Sep 15, 2010
    And do what with the driver,
  • Fabian Chong
    Fabian Chong Dec 08, 2017
    Hello, i sell the pws laptops, this is the complete list of all the printers that it have installe:
    EDOC BROWSER (OMNI BROWSER)
    -1010 DIAGNOSCTICS
    -1065 NVM TOOL
    -1090 NVM TOOL
    -2101 DIAGNOSTIC
    -4110 PWS DIAGNOSTIC TOOL
    -4112/4127 SW TOOL
    -4590 PWS DIAGNOSTIC TOOL
    -4594 PWS DIAGNOSTIC TOOL
    -5065 NVM TOOL
    -5090 NVM TOOL
    -5100 NVM TOOL
    -5100 ELECTRONIC SERVICE LOG
    -5365 NVM TOOL
    -5800 ELECTRONIC SERVICE LOG
    -5800 CALL FLOW
    -5800 NVM TOOL
    -6100 SCP, CONFIG DB
    -6135 SCP,CONFIG DB, SCP
    -6180 SCP, CONFIG DB
    -700CP, NVM ACCES/SW TOOL
    -D135 NVM TOOL
    -DC2045 EPC DIAGNOSTIC
    -DC2060 EPC DIAGNOSTIC
    -DC220/230 ALTERNATE BOOT, DATA MAN, ELECTRONIC SERVICE LOG
    -DC2240/1632 DIAGNOSTIC
    -DC332/340 ALTERNATE BOOT
    -DC332/340 DATAMAN
    -DC332/340 ELECTRONIC SERVICE LOG
    -DC3535 DIAGNOSTIC
    -DC420/440 ALTERNATE BOOT
    -DC420/440 DATAMAN
    -DC420/440 ELECTRONIC SERVICE LOG
    -DC5000 PWS DIAGNOSTIC TOOL
    -DC5252 EPC DIAGNOSTIC
    -DC6060 EPC DIAGNOSTIC
    -DCS20 SOFTWARE UPLOAD
    -DCS20 TTY
    -DCS35 2 X 40, SOFTWARE UPLOAD, TTY
    -DCS40-65 ALTERNATE BOOT, DIAGNOSTIC, ELECTRONIC DOCUMENTATION, ELECTRONIC SERVICE LOG
    -DOCU NVM TOOL
    -DOCU12 DIAGNOSTIC
    -DOCUCOLOR 242/252/260 SW DOWNLOAD TOOL
    -DOCUCOLOR 250 PWS DIAGNOSTIC TOOL
    -DT135 NVM TOOL
    -DT65 DP65 SCP,CONFIG DB, DIAGNOSTIC, DOCUMENTATION, ELECTRONIC SERVICE LOG
    -WORKCENTRE 7132 SW DOWNLOAD TOOL
    -WC 7232/7242 SW DOWNLOAD TOOL
    -WC 7346 SW DOWNLOAD TOOL
    -WC 7328/7335/7345 SW DOWNLOAD TOOL
    -WC M24 DIAGNOSTIC
    -WCPP DIAGNOSTIC
    -XC550_560 NVM ACCES/SW DOWNLOAD TOOL
    -PRODUCT UPDATE LINKS:
    -EFILE DOWNLOAD INSTRUCTIONS
    -MY PRODUCT UPDATE LINKS
    -BUSINESS READY FINISHER
    -COLOR C60,C70 PRINTER FAMILY
    -ENGINEERING SYSTEMS,721P,6622,8855
    -ESPRESSO BOOK MACHINE
    -MISCELLANEOUS
    -VERSANT 2100 PRESS FAMILY
    -WIDE FORMAT IJP 2000
    -WORKCENTRE 5890 FAMILY
    -WORKCENTRE 5945,5955 FAMILY
    -WORKCENTRE 7220,7225 FAMILY
    - WORKCENTRE 78XX
    my whatsapp is +52 1 664 133 7404
    I accept paypal....
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Sep 15, 2010
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785169
Points
9440
Hello.
System Fault Code 10-389 refers to a Fuser Nip Contact Failure.
To service the Fuser Nip Failure problem, you'll need a specialized laptop called a PWS (Portable Work Station).
So, unfortunately, this problem needs to be handled by a professional service tech.
Hope this helps.
Hope this helps.
Customize: Reply 1: XEROX DOCUCOLOR 12 :: Xerox - Color :: The Copier Network"" src="/images/cust_r0.gif" border="0" height="13" width="15" />
Anonymous
Level 3:
  • Master 516 Answers
Anonymous
Master
Level 3:
Answers
516
Questions
Helped
255863
Points
1791
2answers
My check engine light won’t shut off after running the app and pushing the clear button
Disconnect the battery and reconnect, if that doesn't shut it off, take it in for service, that's why the check engine light is there!
Sep 17, 2018 • Motorcycles
How to clear code P-04-513
strange obd2 fault code
P0 4513
to clear any
try disconnecting the battery terminals for a bit
then reconnect battery
check fault codes again
closest i could find is
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
Read more at: https://www.obd-codes.com/trouble_codes/
Copyright OBD-Codes.com
the whole list of fault codes odb2
1998 Isuzu Hombre computer won t reset to ready ?
Hi Jay, If the codes keep repeating after being cleared from the computer memory, the faults have NOT been cleared! Regards John
Engine light won't go ouy
Hi Patricia, The fault code indicates there is something wrong with the evaporation system on your vehicle. Take it to a shop and once the fault is rectified they will clear the fault code with their scanner. Regards John
Reset computer 2004 impala
Clear Codes & Remove the dash check light ?
Codes Reader or Professional Scan Tool
If you disconnect the battery you may loose
things you need & really cause problems
I suggest you get the car repaired & then the light
will go away or be cleared at the repair shop when they
no longer need the stored data
You clear it, they can not diagnose the issues
If fault isn't repaired the light comes on until it is
& you won't be allowed to go thru inspection either
Vauxhall astra abs fault codes
Finding the fault code will not clear the problem if you reset the system without finding the cause the light will just come on again or the fault code will not clear.
Anything related to brakes should be checked out by a garage/mechanic and not ignored.
Its probably just an abs sensor failed but its better to be safe than sorry.
Sorry for the lecture but I wouldnt like to see anyone hurt due to brake system failure.
How do i reset service light
The light is indicating a fault. The computer stores the faults codes, and a scanner can extract the codes and clear them, if desired. Recommend you get the codes before clearing them.
If you have already obtained the codes and effected repairs, the system will rerun diagnostics as you drive and will clear any fault codes that are no longer detected.
If you have more questions, please let us know.
1helpful
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
