IM NOT SURE HOW TO INSERT MY SD CARD ON THE CARD READER TRAY THAT MY COMPUTER CAME WITH. I CANT FIND ANYTHING RELATED TO THE CARD READER MY COMPUTER CAME WITH.
Your SD card will only fit into of of the slots on your card reader.
look at the card reader and look at your card. There should be a **** that is on the card reader almost the same size as your card. Insert it into the slot.
You can save videos to SD card by following these steps.
1.Purchase a micro SD card adapter, which will allow you to insert the smaller card into SD card readers and computers. Many of the newer phones come with the adapter.
2. Insert the micro SD card and adapter into the card reader. Make sure your computer recognizes by accessing "My Computer" on your PC and clicking on the drive letter associated with your card reader.
3.Drag and drop videos or other data to the drive containing the micro SD card. Or right-click on anything you want to save, and then click on "Save As." Save the file to the correct drive.
4.Pop the memory card into your digital phone. Access it using the "Tools" menu on the phone.
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you.
http://www.sdcard.org/consumers/formatter_3/
Hello. You can transfer it without the USB cord and camera IF you have an SD card reader. Some computers have already built in card reader, so if your computer have one, just insert the SD card and start uploading. But if your computer doesn't have it, then you need to get a card reader, insert the SD card into it, and then insert the card reader into a USB slot in you computer. Card readers are really cheap.
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
drives.
5
in the first place.
6
