Hi
I have a M4097D, scans fine from the flatbed but can't scan with the ADF, I get error 20094 Peripheral cover open, or ADF cover open.
Could anybody tell me where the sensor is located and/or any other information, test or solution for it?
Sincerely
ET
This may help:
I don't have a Fujitsu, but a M/F is a M/F, all fairly similar.
On my SAMSUNG CLX-3170FN, I lifted the ADF cover, which is the smaller cover on top of the ADF, found a small black wedge-shape plastic arm which protrudes through the center, upwards.
As this peripheral ie, envelope / postcard / non-standard stationery cover is lowered, it pushes this arm to activate a limit switch, hidden under plastic of ADF.
If the cover is looseor not properly closed, the gearing and roller-feed mechanism can't push paper through, so causing an error.
The reason it refuses to scan is probably a cover not pushed down, or the sensor limit-switch misbehaving.
Renewing the limit should be fairly simple, if similar to mine.
1: Raise the peripheral cover.
2: Loosen 4 screws holding peripheral base-plate.
3: Switch is visible.
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
SOURCE: How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
SOURCE: Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
SOURCE: how to remove and replace adf lid and gears for
http://www.precisionroller.com/trays-for-hp-officejet-pro-l7590/details_54680.html for the tray $46
Circuit City has the whole printer for $150.
SOURCE: When using the ADF for scanning to pdf, it creates
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
