SOURCE: does not select the letters that you want
I saw that someone suggested that I hold the power button for several seconds
until i got more on screen instructions - follow the bouncing dot and it seemed to
clear the problem - time will tell
SOURCE: I'm getting inaccurate letter entry
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To recalibrate the touchscreen on your nuvi 200 series follow
the steps below:
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to
follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow
the steps below:
