Garden Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This is a Karcher 3000 psi unit with the Honda engine, after using it I saw emulsified oil all over the front just below the pump. I'm assuming a seal is gine but haven't torn into it yet. What's going on here?
Ralph Cronenberg
Level 3:
Master:
  • Master 449 Answers
  • Posted on Sep 15, 2010
Ralph Cronenberg
Master
Level 3:
Master:
Answers
449
Questions
Helped
119156
Points
1049
Your leaking oil from some ware and youshould find it before you ruin your pump
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
7helpful
Need to know what oil to use for oil change in the kracher by honda
engine oil....10-30...sh/sj.......19.52 oz do not over fill
oil in pump is a special oil through karcher....3.52 oz of pump oil
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
2answers
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
2helpful
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
11helpful
2answers
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
1helpful
Where do I look and what am I looking for when checking pump oil level . Honda / Husky 3200psi bought reconditioned from home store with out papers .
The pump oil reservoir and pump pistons are between the Honda engine and the business end of the pump. It rarely brass, like the pump. It may be square or tubular. Some of these units have a site tube on the side, some don't. Some have an oil drain plug (bottom) and a plug to put oil in (top). If not, you have to take the pump off. Either way, be sure to use NON-detergent oil and only fill it about 1/3 to 1/2 full.
1helpful
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
2helpful
2answers
Karcher 3000 psi won't start.
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
