Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
Posted on May 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Makita 18v 120volt american charger to be used in australia
I have recently purchased a 18v liion makita cordless tool kit and would like to have the charger reworked to suit 240 volt
  • dontbescared May 16, 2008
    the charger is 120 volt im hoping that an easy modification is possible
  • Anonymous Apr 21, 2009
    Will it required the same procedure to convert the Makita dc 1439 from 110v to 220v?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
17540
Points
11
Don't go buying more stuff when you can fix the problem yourself without buying any converter. The modification required to do it is very easy and most people wont have any problem following it.
You can go to this webpage where a detailed walkthrough is given (with pictures):
http://www.byggebolig.no/index.php?topic=5572.0
Some of the post are in norwegian but the walkthrough is in english.
Good luck and happy moding :)
P.S.
For those of you that have "blowed up" a makita charger 110v on a 220v, don't throw it away!
If you are lucky you have only blowed up the fuse and the varistor, which are easy to replace, and if you follow up the walkthrough you might even go all the way a mod the charger to 220v.
I know, I have already manage to "save" a blowed up charger.
Avi
Level 2:
An expert whose answer gotĀ voted for 100 times.
Sniper:
  • Expert 66 Answers
  • Posted on Jan 10, 2009
Avi
Expert
Level 2:
Sniper:
Answers
66
Questions
0
Helped
79269
Points
177
Hi all,
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
  • Avi Apr 12, 2010
    plumbob71
    sorry for your lose
    In my mod page it says you might also need to replace the MOSFET
    this is not always necessary as some users reported it works w/o replacing it. In addition, did you replace 1 or 2 capacitors ? I was experiencing the same issue and thus wrote 2 capacitors needs to be replaced.
    As for the cost, please note that someone is making a profit from you, it should not cost that much ;-(
    Hope this helps
    Avi
  • Gam Kagan
    Gam Kagan Nov 23, 2016
    Avi - How do I mod a USA bought Makita DC18RC charger to work on 220V overseas?
Anonymous
Level 1:
  • Posted on Aug 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10716
Points
I purchased a new capacitor, varistor, fuse and a new plug and carefully soldered in the new parts. I connected a battery and with a long extension lead stood back. As soon as i flicked the switch on a tiny puff of smoke and a small pop came from the charger. I have spent hours trying to work out what went wrong. $40 in parts and it destroyed a perfectly new battery. Big disappointment.
  • Anonymous Oct 23, 2011
    I think it is damaged beyond repair. You are messing with very dangerous voltages and could hurt yourself. You should buy a new charger for your home voltage.
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on May 16, 2008
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
60663
Points
257
'Tis not so easy as it would require a different transformer. Praying that the stock transformer would support both 240/120 might be hoping for a bit much. Aplliances that support both voltages (such as computer power supplies) usually have a switch on them for doing so.
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Oct 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
38777
Points
14
There are several revisions of this charger, and the physical layout is different. I've seen two sets of instructions for converting from 110 to 220 on the net for the S and T versions.
For the S version: http://www.byggebolig.no/index.php/topic,5572.msg49030.html#msg49030
For the T version: http://www.schneordesign.com/Avi/Makita/makita_mod1.htm
There are different components to change in each version, so you need to use the right instructions. In the T version, the existing Mosfet seems to be able to handle the higher voltage, but Makita uses a 900v Mosfet in its real 220v version. If you want to be cheap, you can use the existing one.
A
Anonymous
I have a Makita DC18RA Li-Ion 18V Battery Chargermakita 18v 120volt american charger to be used in  - s.gif it was from america i bought a converter and plugged it in to 240v not knowing it was 120v it went bang is it knackered??
    I don't know how much you destroyed by plugging it in to the wrong voltage. Very likely the varistor, fuse, 2 input capacitors and power switch are burned out, but I'd have to see it. I think the parts cost is more than a new charger would cost, so for your budget and your safety I suggest buying a new one.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
8948
Points
Will the same solution required to convert the Makita dc1439 from 110 to 220 volts?
How do i change the brushes on a 18V Makita BGA452 Grinder
With a little screwdriver you shall first remove the first dustcaps and then you see the brush holder caps which have to be removed with a suitable screwdriver thats by the most machines not hidden but however by this tool
Charger hy66-30 Makita drill
Is that with the 24v batteries? Where would you be? I'm in Australia, and Makita doesn't sell anything with 24v batteries here. however there seems to be a few going on the UK ebay site. I hope that helps.
2answers
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
1helpful
What is the part number for the makita cordless angle grinder spanner wrench
The Makita part you are looking for is:
782424-9, Lock Nut Wrench 28 for the BGA452
2answers
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
Replacement MAKITA 6391D battery pack 100% compatible with the original 6391D battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_6391D_power+tool+battery.html
Jul 06, 2012 • Drills
My Makita cordless angle grinder (new, used once) BGA452 wont go, it starts then the overload light comes on and it stops? changed battery, still happens.
Obviously too late for you, but it may help others.
I had the same problem with a new Makita 18v lithium grinder and this worked.
Remove battery, remove brushes. Using good quality cotton buds, dip in Methalated spirit and insert into hole for brush down to armature, slowly rotate head of machine. Change cotton bud and repeat process, then clean the brush heads. Re-assemble and try. Note: Meths will dry completely leaving no residue, unlike turps etc.
2answers
I need the owner's manual for an dc18sc makita driver and charger
I couldn't find a Makita DC18SC manual for you, but here is a DC18SC Makita breakdown for you with a list of parts for future use.
Hitachi Charger convert to 230v from 110v how to
Hi mate,you need a step down/step up transformer,try e-bay they sell tons of them..50-100 AU$
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
