Over 2 year old and awakened,
got driver from what site.??
99% of all sites are wrong.
only gateway driver work, or from microsoft PnP
but microsoft ended XP support
and IE6 to 8 is now banned on the internet, IE11 run but never on XP,
who;s xp disk.?
gateways real disk matching THIS PC.
homemade
off torrent,
where?
why not skip wifi and use Ethernet.
if Ethernet works then now plug and play might work
but you did it backwards.
ethernet is always first, for PnP to work out the garage.
is the wifi card even in this PC, most this old it was an options
if the card is missing we have no brainer issue. right.?sure.
and the 2 antennas not fell off,bingo
and the bios for wifi not disabled.
or the card even bad this old,COMMON.
then the gateway driver works, but wait, some PC (most)
had 4 cards use there and the driver must match the card and XP
what tech does
is this
we run hwinfo32.exe free, to find what is inside this PC.
save and sure. here.
https://www.hwinfo.com/download/
not only that may see CPU overheat on this relic PC
let me guess the wifi usb dongle is dead due to maker,
does not support XP, most do not now.
18 years later, XP is now dead, for sure.
you are in the 0.2% world percentile of xp users, sad to watch this.
XP is too old to access the internet anymore! MS stopped updating or supporting XP years ago. Any system they stop supporting will eventually not be able to communicate with the internet. Operating Systems(XP) have to be update to communicate with internet upgrades, once that update process stops, your XP or others, will no longer work on internet.
time to buy new pc and windows os, ie. Windows 10
SOURCE: Wireless Adapter not working under Vista
Yes there is an oblong button. Under XP the button lights up and the wireless adapter works fine. Under Vista the button does not light up and the wireless network does not work. Have tried pressing the button but nothing. The wireless adapter is present and according to device manager is working however when I try to activate a windows help box pops up and tells me I need to turn on the wireless adapter by pressing the button on the front of the computer. Doesn't work whatever I try but it works fine under XP
SOURCE: wireless driver for Gateway mx3228 disappeared after restore
UI Package and driver (support Win98WinMEWin2KWinXPVista)
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PFid=1&Level=6&Conn=5&ProdID=35&DownTypeID=3&GetDown=false&Downloads=true
or search and download "Drive Genius"
SOURCE: Need driver for Gateway wireless
You can download the drivers, from the following website
http://support.gateway.com/support/drivers/search.asp?st=pn¶m=5959
Thanks
Proton
SOURCE: can't enable Dell Wireless 1390 WLAN Mini-Card
I was using the wireless network, disabled the radio and after reboot was unable to get it to save the enable click. After reviewing all software options listed here - checked wireless adapter setting in BIOS - it was turned off! Turned this on in BIOS and upon boot was able to access wireless network again. Hope this helps you.
SOURCE: I have a mx6025 gateway notebook. I installed
When i checked, i can only find the Conexant Audio Driver Version: 6.14.10.0565 for this model.
Is that the driver which u tried?
