Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
Hi
Error
code IE on LG dishwasher means Inlet error. This error comes up when the Water
Supply Tap is closed or Water Supply is shut off. If water supply is turned on
then make sure that the Inlet Hose is not kinked and water Pressure is not low
(should be above 10 psi). Next thing to check for is Water Inlet Valve, measure
the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of
Inlet Valve is not clogged.
Hope this helps... Please post back
for further assistance.
Daniel
