The green power light will not stop blinking and the tv will not turn on or off. WE have tried pushing the reset button as suggested in the manual and unplugging it from the wall. Neither have worked. TV is always plugged into APCSurgeArest and was turned off for the night. Had power failure during night. Found green timer light blinking this AM. will not stop flashing. Tried unpluging, holding menu button on front panel for 8 sec, pushed reset on front panel, holding 9 and QV buttons down on remote control--everything the manual said to do plus tried a different electrical outlet--been 8 hrs & still flashing
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
I have Mitsubishi ws-55859 and I was reading about the green light blinking. Ours happened when the power went out. When it came back on the green light just stayed blinking. Can I buy the capacitors and are they the same ones for my model as the one you told for ws-55909? Sherry in Oklahoma
[email protected]
Same exact incident as mentioned in the problem that I am commenting to.
same problem - power went out - green light keeps flashing can't turn tv on
same exact problem....green power light flashing. no power. Have unplugged and tried all the aforementioned solutions with no success
I have the same problem as described by rrogers. Because I did not have a manual I only tried unplugging the TV and pushing the reset button.
the problem is that the TV doesn't power up.when I plug it into the outlet the green light flashes on and off then suddenly stop. I then push power button and nothing happens, what do I do next?
