Master
- Posted on Sep 16, 2010
Re: I have a bent rear fork on my Jazzy jet 3 I cannot...
Wbritt You can call Pride Mobility @ 1-800-800-8586 select parts and order part # FRMASMB3772 make sure to ask if that is the correct part # for the rear caster assembly Hope this helps
Pride Mobility will usually forward you to a technician in your area. You can opt to find your own parts by searching the web. Sometimes ordering this way can result in getting the wrong part. If you provide the tech the serial number of the chair this can be cross referenced with the manufacturer and then the guess work is out. Talk with your local tech. The best way to find a tech is to call Pride Mobility and ask for a local Tech phone number. 1-800-800-8586
