Question about Nintendo Wii Console
Error 52020 code wii - Nintendo Wii Console
    Scholar:
  • 142 Answers
Posted on Oct 02, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
this is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Posted on Jan 01, 2011
    New Friend:
  • 26 Answers
    Connecting directly to a modem:
  1. Power off the Wii. Connect the Wii LAN adapter to the Wii, and insert a working ethernet cable into the Wii LAN Adapter.
  2. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  3. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  4. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
Posted on Sep 14, 2010
5 Suggested Answers
SOURCE:
amsmith525
  • 99 Answers
SOURCE: bought a pre owned wii and im trying to hook it to
What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE.
Posted on Mar 15, 2011
  • 33 Answers
SOURCE: i have internet through cable.it runs through the
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
Posted on May 05, 2011
beatles98
  • 11 Answers
SOURCE: im trying to connect my
You probably have a firewall on your PC (or mac), or router preventing you from connecting to the internet, either plug the cable to the router, disable the firewall (if using a Netgear router, disable the "SPI firewall" under the "WAN setup" of your router), your Internet Service Provider or ISP might be preventing systems like the wii to connect, check with the ISP to see if they are or not.
Posted on May 07, 2011
  • 55 Answers
SOURCE: have connected wii to cable via cisco asa 5505
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Posted on Aug 09, 2011
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Aug 09, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
if this help you please rate me thank you sir.....
Jul 05, 2011 | Nintendo Wii Console
Error code 52020
Check out the Nintendo guideline
Tell me if you fixed it.
May 22, 2011 | Nintendo Wii Console
Im trying to connect my wii to the internet .I have the lan adapter connected to my modem. I am not getting a connection and error code 52020 is on my screen. what am i doing wrong?
May 07, 2011 | Nintendo Video Game Consoles & Games
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
Mar 15, 2011 | Nintendo Wii Console
Keeps showing error code 52020
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=lang
Jan 28, 2011 | Nintendo Wii Console
WHAT IS ERROR 52020?
It is an error of falior
Oct 31, 2010 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
The wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Jun 12, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
892 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
