Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on Scanner System Failure Scanner failed, cannot make copies or fax Scanner failure. Unable to scan, copy, or send a fax Scanner failure, cycle power
You may want to try following these steps: 1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product. 2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer. 3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
I have the exact same problem as well!
